1996 Chevy Blazer 96 Chevy Blazer wont start
SHAYTON918
  • 1996 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 175,000 MILES
I have a 96 chevy blazer which will not start. It turns over great but just wont start. I can hear the fuel pump kick on. So I dont think thats it. When I pour gas or even spray starter fluid into the throttle body it still will not start. Figuring then it would be an ignition problem so I changed the ignition control moduel, rotor, distributer cap, and coil. After all that was replaced it still wont start. The battery is also brand new.I dont know what else to try anymore. What else could be the problem?
Saturday, February 14th, 2009 AT 4:04 PM
You missed one the crankshaft positioning sensor this is the one that tells the computer to fire the coil
Friday, January 29th, 2021 AT 12:57 PM
SHAYTON918
Where is the crankshaft sensor located? Is it easy to change or does it have to be taken into a shop?
Its on the front of engine near crankshaft pulley. You can replace it yourself.
SHAYTON918
I just wanted to thank you for your advice. I just got the blazer up and running today. It ended up being the wiring under the steering wheel.
