1994 Chevy Blazer Fuel Pump Replacement
DILLINGER1958
  • 1994 CHEVROLET BLAZER
  • 4 CYL
  • 21,700 MILES
I replaced the fuel pump and the car wont work. I hear the pump start up and verified that there is gas getting to fuel rail on top of the engine. I have checked the ecm10 fuse and it is fine. All fuses are good. I was told that the 4.3 Vortec engine must have precise fuel pressure or it wont start. What is the spec as far as what PSI the fuel pump needs in order to work. I will check with Autozone to see if they sold me the right psi fuel pump, but I would need to know what the spec is for fuel pressure. Any help would be greatly appreciated.
Thursday, June 3rd, 2010 AT 5:13 PM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_1994_S10_blazer_fuel_pump_specs_1.jpg
This is for the S-10 blazer i hope that's what you have.
Thursday, June 3rd, 2010 AT 5:23 PM
