HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Blazer
Fuel System
Fuel Pump
Replace/Remove
SPONSORED LINKS
1994 Chevy Blazer Fuel Pump
TROUBLEKA
MEMBER
1994 CHEVROLET BLAZER
Computer problem
1994 Chevy Blazer 6 cyl Four Wheel Drive Automatic
We change the fuel pump in the Vehicle and now it will not start HELP?
Sunday, April 19th, 2009 AT 8:57 PM
BLUELIGHTNIN6
MECHANIC
Can you hear fuel pump kicking in at all? Or is there just a clicking noise upon turning ignition?
Inspect fuses and fuel pump relay.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Monday, April 20th, 2009 AT 12:27 AM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1994 Chevy Blazer Replacing A Fuel Pump
Engine Mechanical Problem 1994 Chevy Blazer 6 Cyl Four Wheel Drive Automatic I Just Wanted To See What Tools Are Needed To R/r A Fuel...
Asked by
djpyrat
1 ANSWER
1994
CHEVROLET BLAZER
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
1994 Chevy Blazer Fuel Pump Replacement
I Replaced The Fuel Pump And The Car Wont Work. I Hear The Pump Start Up And Verified That There Is Gas Getting To Fuel Rail On Top Of The...
Asked by
dillinger1958
1 ANSWER
1994
CHEVROLET BLAZER
Won't Run
I Started Having Problems When My Fuel Pump Went Out. I Have Changed My Fuel Pump And My Fuel Filter. After That, When It Warmed Up It...
Asked by
Amberbabiee
1994
CHEVROLET BLAZER
How To Change Fuel Pump
I Need Help Changing My Fuel Pump
Asked by
rkuhaneck2002
11 IMAGES
2002
CHEVROLET BLAZER
Fuel Pump Removal
What Do I Need To Do To Replace The Fuel Pump?
Asked by
jpellinen
6 IMAGES
1995
CHEVROLET BLAZER
VIEW MORE
SPONSORED LINKS
How to fix an engine that wont start
Fuel Pump Pressure Test
Engine Not Starting
Online car repair manuals
