After checking the gray wire, I droped the tank agine and checked all the different points for current. Personal note, it helps to find a good ground for the circuit tester. Had current all to way to the connecter harness for the pump. Moved the prong a little bit closer together to where it would make great contact to the prongs on the pump. It works great. Old pump was bad, hooked it to the battery and it did not work, good thing it got replaced. Thanks guys.
Wednesday, March 12th, 2008 AT 10:04 PM
