Engine Cooling problem
1992 Chevy Beretta 6 cyl Front Wheel Drive Automatic
my raditor fan will not turn but I have checked and the fan motor is still good what else could be wrong
Saturday, June 12th, 2010 AT 5:14 PM
MECHANIC
Probable causes here could be the fan relay, coolant temperature sensor, engine coolant temperature gauge switch or wiring and the computer itself
SPONSORED LINKS
Saturday, June 12th, 2010 AT 5:31 PM
JIM SHIRRON
MECHANIC
You probably need to find a tech with a "scanner". He can watch coolant temp. If sensor is ok, fan should be turned at 195-215 degrees. If fan is commanded properly check relay and fan ground.
