My girlfriend has a 93 Beretta, AT, AC, aprox 173,000 miles. She says it over heats when going through traffic and redlights. Does pretty good on highway as far as temperature. I think it is the fan not running when it should. When I tested for codes using the wire method, I noticed the fan runs while doing this, but it may not be coming on when it should. Would that be a temperature sensor? I understand the fan runs off of the ECM.
Thank you for any info.
SPONSORED LINKS
Friday, August 24th, 2007 AT 5:30 PM
