2004 Chevy Aveo Heater core location
101,000 MILES • 4 CYL • FWD • AUTOMATIC
LANZELOT
Smells like coolant and get foggy (haze) windows with the heat on. It should be the coolant.
Where is the heater core in my Aveo 2004?
By a professional mechanic how long would you estimate the repair time?
Thank you very much!
Dec 12, 2007 at 3:25 PM
DENNYP
  • 1,824 POSTS
It is located inside the big black box under the dash.The dash will have to be removed to get to the heater core.I don't recommend you try this one at home,unless you have a good knowledge of automotive repair. A shop would probably charge you around 7hours labor.
Dec 15, 2007 at 7:30 AM
