coolant system
CHEVROLET
INEEDMONEYS
what does it means when the liquid in the coolant system turns to yellow goo & what is the best cooler to use in a chevy aveo lt 2005 at 36000 miles
Oct 28, 2007 at 8:34 AM
  • 75,988 POSTS
It means it needs cooling system flushing and an antifreeze 50/50 solution mix
Oct 28, 2007 at 9:10 AM
INEEDMONEYS
Thanks do you know the least amount of price I should pay for these products to use on my Chevy Aveo
Oct 28, 2007 at 9:29 AM
  • 75,988 POSTS
To: INEEDMONEYS
Posted: Sun Oct 28, 2007 3:41 pm
Subject: Re: Thank You
You can do this yoursel-just find the radiator drain plug open it up let all the coolant out, remove the radiator cap stick in the water hose let it run as you filling up run the engine till it clears about 20 mins. then stop the engine and fill it with new antifreeze.
About price dunno about your local area-2 antifreeze gal cost about $10.00 a piece =that's 20.00 it will probably cost with labor about 60.00.
Oct 28, 2007 at 9:46 AM
INEEDMONEYS
i purchased the prestone 5/100 extended life antfreeze & coolant because the sales person said that this is for any chevy 2003 and up although i told him my veh is a 2005 chevy aveo does it make a difference?
Oct 28, 2007 at 2:19 PM
  • 75,988 POSTS
Get the yellow gallon( Prestone) and make sure you ask, is it compatible to DEX-COOL license under DC-002 if not and anything goes wrong with the cooling system under the 5yr/150,000 warranty its gonna come out of your pocket.
Good Luck
Oct 28, 2007 at 4:36 PM
INEEDMONEYS
Thanks again do you know how long I can operate my vehicles for as long as this problem appears
Oct 29, 2007 at 9:32 AM
  • 75,988 POSTS
Dunno but I change mine every year for preventive maintenance. I don't want no surprises.
Oct 29, 2007 at 11:43 AM
