'95 Astro fuse block wiring diagram
1995 CHEVROLET ASTRO
PASBONSIMON
I have replaced the under dash fuse block of 95 Chevy Astro 4.3 2wd 285,000 because of several fuse issues. Everything is in working order except the VSS Vehicle Speed Sensor. (no speed odometer operation and tranny does not shift) I need a fuse block wiring diagram so that I may trace the VSS wires to make sure they are wired correctly. They worked before my transition. I have a Chilton and Haynes manual. They supply wiring diagrams for the VCM but but not the fuse block. I have come across a fuse block diagram from a 96', but it is different than '95.
this is a helpful link, but still no fuse box diagram
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/11/91/01/0900823d80119101.jsp
Thanks for your assistance
pasbonsimon@cox.net
Feb 16, 2007 at 10:01 AM
PASBONSIMON
anyone have ChiltonPro?
Feb 16, 2007 at 10:53 AM
LYTN_J
  • 19 POSTS
The information I have, shows the vehicle speed sensor buffer and instrument cluster work off the same 15 amp brake fuse.
Feb 19, 2007 at 8:21 AM
PASBONSIMON
thanks - you are correct
It is back on the road
Feb 21, 2007 at 1:05 PM
