1994 Chevy Astro no electrical power
1994 CHEVROLET ASTRO
SHRPWOOD
Electrical problem
1994 Chevy Astro 6 cyl All Wheel Drive Automatic
the battery is new but theres no power to lights or starter
Oct 27, 2008 at 3:14 AM
JDL
  • 16,098 POSTS
Even if the battery is new, you need to make sure it has a good charge. Make sure all wires and cables coming from both battery posts are clean and tight.
If your saying the headlites don't work, the feed to the headlamp switch is hot all the time, comes from fusible link at battery junction, follow the smaller wire from the + battery posts. One way to test a fusible link, if it has voltage coming in one side, there should be voltage going out the other side.
The smaller purple wire at the starter solenoid should be hot with the key in the crank position. If you do any testing at the starter solenoid, make sure the tranny is in park or neutral and the e-brake is set.
Oct 27, 2008 at 6:42 AM
