92 astro fuel pump
DDOGG7864
My 1992 Astro with 130,000 miles died yesterday. It will start and run if I spray starting fluid in the throttle body so I assumed it was the fuel pump (could not hear it running when key was turned on). So I dropped the tank and replaced the pump and the filter. The new pump does not run either. Is there a relay that sends power to the pump that I can replace? Where is it? I have not tested for power at the pump because I did not want to pull the tank out again. It is a 4.3 v6 automatic with a z vin#
Nov 19, 2007 at 1:43 AM
MERLIN2021
  • 17,250 POSTS
Your fuel pump relay is on the firewall, abve the blower motor..
Nov 19, 2007 at 4:30 AM
