No Brake Lights
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEREHTR
Hi, I have a 2001 Chevy Astro with 85000, and I have two problems. First, I have had a recent issue with the turn signals not blinking when braking. That happened to me this morning. Second, I had an error code which came up when my Service Engine Soon light came on. The code is P0341, and it says, 'Camshaft Position Sensor A - Bank 1, CKT Range/Perf'
Anyone know what to make of either of these issues?
Thanks, J
Jun 27, 2008 at 4:33 AM
JDL
  • 16,098 POSTS
Are you saying the turn signals work fine when you don't step on the brakes?
The brake lites and turn signals use the same voltage circuit, just not at the same time. That circuit is controlled by the turn/hazzard switch. When you engage the turn indicator switch, it kills the brake lite on that side only.
Jun 27, 2008 at 6:13 AM
JEREHTR
Yes, I am saying that the turn signals just stay in the 'on' position when hitting the brakes.
thanks,
Jeremy
Jun 27, 2008 at 7:10 AM
JDL
  • 16,098 POSTS
In the rear, the brake lites and turn signal use the same bulb fillament, they can't work at the same time.
When you use the turn signal lever for a left turn, you won't have a brakelite on the left side, you should have turn signal, though. You will still have brake lites at the high-mount brake lite and brake lites on the right side.
Maybe I misunderstood your question, somehow?
Jun 28, 2008 at 3:50 AM
JEREHTR
I think I didn't communicate it well.
My signals don't blink, but just light up when applying the brake pedal. Otherwise, when I am coasting or hitting the gas pedal, they blink like they normally should. This problem happened just yesterday on the way into work. Any thoughts? Could it possibly be that one of the bulbs is going (or is already shot?)?
Jun 28, 2008 at 6:08 AM
JDL
  • 16,098 POSTS
Are you saying none of your turn signals work, front or back, when step on the brake?
You may have to check the turn/ hazzard switch.
Jun 28, 2008 at 8:13 AM
JEREHTR
yes, the arrow stays lit up, but it doesn't blink when I brake.
Otherwise, it seems to blink just fine.
thanks!
Any thoughts on the error code P0341?
Do I just have to replace the camshaft position sensor?
thanks...
Jun 28, 2008 at 8:17 AM
JDL
  • 16,098 POSTS
Looks to me like your going to have to check the circuits at the turn/hazzard switch.
As far as the cam sensor, that's a hall switch, three wires, ref voltage, ground, signal. I'd check those before I did anything else.
Jun 28, 2008 at 8:57 AM
CAMORALES29
I HAVE PROBLEM WITH MY STOP LIGHTS AND I CHECK WITH THE ELECTRIC DROWING WHAT WILL BE THE PROBLEM BUT I CANT FINE ANY THING WRONG REPLACE FUSES REPLACE BULBS ALL SIGNALS WORK AND THE STOP LIGHT LOCATED ON THE TOP IS WORKING BUT NOT HTE SIDE ONES
Apr 20, 2020 at 3:32 AM (Merged)
  • 75,988 POSTS
Hi CAMORALES29 and TY for the donation
Check and test the brake switch if okay its coming from the turn/hazard switch the bottom light goes thru this switch then to the bottom light
PACSOUND
I have a 2001 Chevy Astro 2wd 4.3L 177,000 miles.
The brake lights do not work. The center brake light works, hazard lights do not work, turn signals do work. The harzard fuse is good, all bulbs are good. and I have changed the brake light switch on the brake pedal. I think the hazard light switch is bad. Is there a way to check this without buying a new and place it? The hazard switch cost $301.00. Thank for your help.
Ron
Apr 20, 2020 at 3:33 AM (Merged)
POET042005
  • 134 POSTS
Have you tried scaning for codes.
I believe your right the hazard switch may be bad. ? does the brake lites ever work when the high beams are on.
Also you can find the switch at a much cheaper rate I'm sure check around at your local automotive stores.
SOme will even let you buy the part and if it dose not work return it for refund of course that is as long as it works.
I hope these suggestions help
let me no what happens
Richard
JIM J
Hi I have a 1998 Chevy Astro Van with a 6.1 engine and Automatic , It has 200,050 Miles and I had a trailer hooked to it with maybe some bad wires but im not sure , so any way the brake lights quite. the over head brake light comes on and the turn signles do work however the hazared seem to require a wiggling of the red swith in the up position to work but wont stay on. I have chaned the two bulbs and checked all the fuses , can you head me in the right direction ...... Thanks
Apr 20, 2020 at 3:34 AM (Merged)
PEELERS
Have you found a solution to your brake light problem. I am having the same problem with my 2000 astro after wirring trailer lights
JIM J
no i did not find out what caused it but what i did was wire the overhead break into the right side brake light and that had them both come on (left and right ) however my overhead blinks along with the turn signle and the left turn signe quits when I hit the breaks the right one does not
KAMOLTHANAVARO
[quote:a76cfc0994="Jim J"]Hi I have a 1998 Chevy Astro Van with a 6.1 engine and Automatic , It has 200,050 Miles and I had a trailer hooked to it with maybe some bad wires but im not sure , so any way the brake lights quite. the over head brake light comes on and the turn signles do work however the hazared seem to require a wiggling of the red swith in the up position to work but wont stay on. I have chaned the two bulbs and checked all the fuses , can you head me in the right direction ...... Thanks[/quote:a76cfc0994] I am a Mechanic, But even myself I can't seem to find out what's wrong with one of my costumer's car who has the same problem. If you happen to find out please let me know A.S.A.P.
- thank you
KINGBUBBA
how do you check the brake switch to see if its good and where is the switch located at
  • 75,988 POSTS
Follow the brake pedal arm till it meets the brake support bracket its here-disconnect it and jumper the connector if the lite comes on -try adjusting it properly unable to-replace it
LILCHINA0598
my brake lights are not working. I have replaced the fuse & the bulbs but no go. I read that it might be the brake light switch. Does that sound right? If so, how do I replace it?
  • 75,988 POSTS
Before you replace it-check for power at the orange wire on the brake switch-No power check stop/hazard fuse 20amp. Power there-jump connector with a small wire then check the brake lights -is it On? if so-replace switch and adjust it. Brake lights don't come on when jumpered -you have a problem with the turn/hazard switch power has to come from there to get to the brake lights.
The high mount brake light has a different circuit. If this light is coming On and not the others were right back to the turn/hazard switch-Now if this light is not coming On -its the brake switch-
SVFDC2
1993 chevy astro ext rwd 117,000 miles. the break lights dont work.turn signels and flashers do. any sugestions???????
FISHERMAN
  • 937 POSTS
check the switch on the brake pedal..
SVFDC2
test light shows its ok....
KENVCR
  • 105 POSTS
Did you just recently change both light bulbs?
Check and make sure you have 2057 bulbs in place.
Make sure the offset pins on the bulb are in the correct sides.
NETO69
I have a 1993 chevy astro van and the brake lights don't work. I've replaced all the light bulbs checked all the fuses and replaced the brake light switch also ( except the cruise control switch) and still doesn't work. Any suggestions?
MASTER TECH DAN
  • 83 POSTS
have you checked for power at the brake lite switch
then you need to check the wires and ground at the rear of the vehicle you may also have the hazard switch on you may have a bad flasher for the hazards witch can make the brake lites not work
NETO69
The hazard lights work fine, and no I have not checked if the brake light switch has any power.
