Check engine light stays on
WRENCHTECH
  • 20,761 POSTS
It may take a while to duplicate the circumstances that put the light on but it will likely come on again.
Thursday, February 21st, 2019 AT 5:08 PM (Merged)
RCJKILROY
  • 2007 HYUNDAI SONATA
2007 Hyundai Sonata 6 cyl Front Wheel Drive Automatic
i have a 2007 hyundai sonata v6 the check engine light goes on and off so I bought an obd II tester that works with my car I tested it when the check engine light was off and it read that there was a fault but when I check to see the code it came up as n/a is it because the light was not on?
Light or no light if its has a stored code/s in it -it will indicate on the reader-you must have erase it-
  • 52,797 POSTS
There is no sensor. The ecm is what monitors parameters and when a component is out of range it will set a code.
Thursday, February 21st, 2019 AT 5:31 PM
