Check engine light stays on
110,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
WRENCHTECH
  • 20,760 POSTS
It may take a while to duplicate the circumstances that put the light on but it will likely come on again.
Feb 21, 2019 at 9:08 AM (Merged)
RCJKILROY
2007 Hyundai Sonata 6 cyl Front Wheel Drive Automatic
i have a 2007 hyundai sonata v6 the check engine light goes on and off so i bought an obd II tester that works with my car i tested it when the check engine light was off and it read that there was a fault but when i check to see the code it came up as n/a is it because the light was not on ?
  • 75,988 POSTS
Light or no light if its has a stored code/s in it -it will indicate on the reader-you must have erase it-
There is no sensor. The ecm is what monitors parameters and when a component is out of range it will set a code.
Feb 21, 2019 at 9:31 AM
