Monday, January 7th, 2008 AT 9:38 PM
Check engine light code indicates all cylinders misfired, car can run for approximately 15 minutes or 10 miles before the car shudders and the cylinders stop firing causing the rpm's to go to zero and the car to eventually stall. Thought it was the coil pack which I just replaced but it did not correct the problem. The head gasket appears not to be the problem, it seems to be heat related since it hits a certain time or mileage every time it happens especially if It gets stuck at red lights where the vehicle is not getting air flow. Any suggestions or recommendations?
