After replacing the head gaskets, engine cranks and backfires, but does not start?
125,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
NEISWONGERSHAWN
I changed the head gaskets, cleaned the engine block pit, new oil, new oil filter, new coat, new spark plugs, new coil pack and wires, but when I go to start it, it kind of backfires first, then doesn't start... what is wrong?
Mar 12, 2023 at 10:48 PM
  • 55,649 POSTS
It could be you just need to let the engine sit for a day to allow the lifter to bleed back down to the proper adjustment but if you please shoot a quick video with your phone so I can hear the engine cranking over I can tell for sure what's going on.. You can upload it here with your response.
Mar 14, 2023 at 3:54 AM
