2000 Pontiac Grand Am head gasket replacement
2000 PONTIAC GRAND AM
OLDIRTY13
Engine Mechanical problem
2000 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 200xxx miles
I popped head gasket or manifold gasket yesterday. I contacted my "friendly mechanic" & hes telling me "its going to cost $1,200 if it's obvious that the leak/blow-out is the manifold gasket". Which kinda shocked the hell out of me, thinking he was going to give me a good deal. Oh but here's when he says "If its not there & I've got to send the heads off to get magnafluxed". Saddly to say the head gasket is going to run me $1,600. Of course thats only "IF" the heads come back in good shape.
So i'm guessing my question is "Is that a good price? Or should i shop around a little more?
Oct 29, 2009 at 2:33 AM
MMPRINCE4000
  • 8,548 POSTS
Have a compression test performed to rule out/in head gaskets.
If compression is good, have a cooling system pressure test to check the intake gasket.
GM had many problems with intake manifold gaskets, but the two tests above will tell you which one is the culprit.
Oct 29, 2009 at 4:09 AM
