Will not start after changing computer
177,000 MILES • 0.6L • V6 • 4WD • AUTOMATIC
HERRERATINO8687
A friend was giving me a jump and connected the jumper cables wrong and fried my computer. The gas gauge was reading below zero and the truck had no power at all. I replaced the computer with a used one from the junkyard. I have power now but the car won't turn over. I reached the ignition switch and bought a new battery and it still won't start. I tried resetting the computer with some instructions I got off YouTube and that did not work either. Please help
Jun 29, 2021 at 1:18 AM
Good morning,
Can you communicate with the replacement ECM? Does the check engine light work?
When you crank the engine, you should see the tach move up a little indicating the crank sensor is working.
There may be more damage from the cables being hooked up backward.
Check all the fuses with a test light and verify power on both sides of the fuse.
Jun 29, 2021 at 8:26 PM
