When I attempt to start my car it will not crank
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,280 POSTS
Sounds like low voltage or a bad connection at the positive battery cable. Can you load test the battery using this guide? That would help even though it has 14 volts it can have no load capabilities.
Saturday, March 6th, 2021 AT 6:07 PM (Merged)
JASON TILLIS
Amazing. Occam's razor strikes again. This simple thing solved the problem I've spent 2 weeks trying to track down. The corrosion was not obvious to the naked eye, particularly in my poorly lighted household garage. Thank you the brilliant diagnosis!
KEN L
  • 54,280 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
MICHAEL FRANKS
  • 2003 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 200,000 MILES
No power to pcm fuse & pcm crank fuse. Fuses test good. Starter will not engage. No interior lights. Windows work. Battery and alternator test good also
MATHIASO
  • 1,209 POSTS
Hello michael franks
Check the ignition main fuse#5 (40A)underhood, if fuse is ok, check power to the fuse.
Check ignition fuse #5(30A)
https://www.2carpros.com/forum/automotive_pictures/46384_1_8.jpg
Check power to crank fuse,if there is no power, check for an open between Bat+ and fuse block.(see diagram)
https://www.2carpros.com/forum/automotive_pictures/46384_2_6.jpg
Check your email for the diagrams.
SOLDADOTZ712
  • 3.8L
  • 3 CYL
  • 4WD
  • 166,000 MILES
Electrical all works but not turning over.
Saturday, March 6th, 2021 AT 6:08 PM (Merged)
KEN L
  • 54,280 POSTS
It sounds like you have a weak battery or the starter has gone out. here are two guides to help us see what's going on. Can you please shoot a quick video with your phone so we can see what's going on?, that would be great. You can upload it here with your response.
and
SOLDADOTZ712
It was a security lock on it.
KEN L
  • 54,280 POSTS
O yes the security system here is how to reset it
https://www.2carpros.com/articles/how-to-reset-a-security-system
MRSX7
  • 2002 CHEVROLET IMPALA
  • 3.4L
  • 6 CYL
  • FWD
  • 160,000 MILES
Solenoid will not disengage after starting engine. I have changed starter, crank relay, alternator, ignition switch. Did not fix.
STEVE W.
  • 15,314 POSTS
When the solenoid sticks in does pulling the crank relay out stop it? If it does check the yellow wire with black stripe and see if it is grounded. If it is you could have a short to ground in that wire or the PCM is bad. Another item is that the PCM is not getting a signal from the engine that it has started and to stop cranking. For that you would need to connect a scan tool and see if it is responding to the cam and crank sensors properly and that the ignition control is seeing the reference pulse telling it the crank is turning.
ANNA LEE
  • 2004 CHEVROLET IMPALA
  • V6
  • 240,747 MILES
If I put my car in accessory or on mode, the lights, radio, AC, all turn on, but when I try and start the car, the engine will not make any noises. I just hear a few clicks and it shuts off. I am not really sure what to do.
Wednesday, March 17th, 2021 AT 5:20 PM (Merged)
KEN L
  • 54,280 POSTS
It sounds like the battery is dead can you confirm the issue by following this guide?
And if it fails this guide will show you how to replace it.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Cheers, Ken
