If your talking about when I turn the key to "start" the answer is "no", but I do at battery connection post. That is why I needed to know if neutral safety switch is inside transmission on this model, because it is not like most GM's that I have worked on that are on/ part of transmission shifter rod on top of front wheel drive transaxles.
I pickup a Haynes repair manual just now, but I havn't look to see if it's cover in the manual, yet.
I can still use any help you can give and will compensate accordingly.
Thanks again ron m
PS I also found the" transaxle indicator switch" beside the steering column and unplugged & then jumped wires to see if It producted current at "S" terminal with "NO" luck(there is power at one side with key on -before I jumped wires.
Tuesday, September 9th, 2008 AT 10:13 AM
