Car will not start
187,511 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
AGBOOLA ST
Engine is actually rolling but it is not starting.
Apr 22, 2022 at 7:33 PM
SQM
  • 6,383 POSTS
Generally speaking, an engine will need spark, fuel and compression to start.
If the engine is cranking over but not starting it is likely missing or having issue with one or more of these components.
It could be due to an inoperative fuel pump or issues with the ignition.
Does the fuel pump turn on when the key is in the on position?
Do you know if you are getting spark to the plugs?
To figure out what the issue is, you will have to take a look at the possible issues.
Here is a helpful guide that covers what to look for:
https://www.2carpros.com/articles/car-not-running-advanced
Please let me know what you find or if you have any questions.
Apr 23, 2022 at 6:00 AM
AGBOOLA ST
I eventually discovered that the fuel in the tank was contaminated resulting from the last fuel I purchased.
Apr 26, 2022 at 10:19 AM
SQM
  • 6,383 POSTS
Glad you were able to figure out the issue.
Thank you for using 2CarPros.
Apr 26, 2022 at 5:06 PM
