Car will not start
142,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
PCULQUI
  • 354 POSTS
If changing the camshaft position sensor doesn't turn on the car, will replacing the crankshaft position sensor do the trick?
Apr 2, 2019 at 2:23 AM
SCGRANTURISMO
  • 4,897 POSTS
Yes it will. Your vehicle's Power-train Control Module (PCM) interprets the signal from the Crankshaft Position Sensor (CKP) to determine the speed of the crankshaft to aid in the firing of the spark plugs and for monitors such as misfire detection. If your vehicle's CKP signal is not getting to the PCM your vehicle will not start. I have included a few links down below for you to go to down below
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Please go through these guides and get back to us with what you find out.
Thanks,
Alex
2CarPros
Apr 2, 2019 at 3:08 AM
