Over heated now it will not turn over
SPORTSGEEKVC08
  • 1989 BUICK LESABRE
Engine Performance problem
1989 Buick Lesabre 6 cyl Front Wheel Drive Automatic 215K miles
Upon leaving my driveway my Buick decided to die on me. This problem has occurred a few times in the past, however I was able to start the engine back up with no problem and go on my way. This time however, no go. The engine would turn and turn but wouldn't start. I left the car alone for around half an hour and tried to start it up. It started so I decided to take it out for a spin to McDonalds. While idling in the drive through, the car died. I waited a second and the car started back up. On the way home however, the car died once more while driving at a low speed (around 20mph). After a few failed attempts to start, the car had to be pushed home.
Wednesday, November 1st, 2017 AT 8:19 PM (Merged)
Do below to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
FAVRE.4EVER
  • 6 CYL
  • 250,000 MILES
1989 Buick Lesabre 6 cyl Two Wheel Drive Automatic 250000 miles
my car stalls at stop signs and traffic lights when I try to proceed from a dead stop. Then kind of hesitates when I restart it and get going again.
JDL
  • 16,098 POSTS
How long since a tune-up? Any applicable mil codes? Clean the throttle body and check the iac.
FAVRE.4EVER
Thanks for the info, just bought the car and of course everything ran fine when we bought it. Will take you up on the tune up hope it works
EMMETTSOGOOD
  • 150,000 MILES
Wont start yeah. I have a Buick Lesabre that starts. Purrrs. Then dies. Then cannot start again for days. Then start. Purr. Die. Its getting fuel to the intake. 140k 3.6 please help
RIVERMIKERAT
  • 6,110 POSTS
Same answer as your other thread.
RIVERMIKERAT
  • 6,110 POSTS
Check fuel pressure while the engine is running and when you can't start it. Also check for spark when it won't start.
TERESA PERKINS
  • V8
  • 175,000 MILES
Car just shuts off when driving. But if you wait a few minutes it starts up.
Wednesday, November 1st, 2017 AT 8:20 PM (Merged)
  • 109,867 POSTS
This could be several things. First, the vehicle has the OBD1 diagnostic system. Locate the port and jump ports A and B using a paper clip. With the ignition key in the run position, the check engine light will begin to flash. Count the flashes to determine the trouble code stored. With that information, hopefully you will narrow down the problem. To me, it could be a couple things. A bad fuel pump, bad ignition module, crank sensor. There are many possible issues, so the trouble code should point us in the right direction.
