engine want start
2000 OLDSMOBILE INTRIGUE
160,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
JOE1953
  • 794 POSTS
the engine will turn over but it want start it act like it want to start but it want what could be the cause that the engine want start or what do I check?
Feb 1, 2016 at 8:53 PM
CATAFINA
  • 167 POSTS
Check the fuel pressure if okay look for spark then let me know what's happening
Feb 1, 2016 at 9:47 PM
HMAC300
  • 48,601 POSTS
reset anti theft first
Feb 2, 2016 at 6:19 AM
JOE1953
  • 794 POSTS
I check the fuel pressure it show about 42 pound pressure is that the correct pressure? i don't no how to check the firing i didn't see any spark plugs wires how do i check the firing on this car? i read the code in the computer it show PO101,PO135,PO400 will anying of these codes cause the engine not to start?
Feb 2, 2016 at 12:51 PM
HMAC300
  • 48,601 POSTS
Fuel pressure is good codes will allow car to start
Do what I said in first reply
Feb 2, 2016 at 3:40 PM
JOE1953
  • 794 POSTS
how do i check for spark?
Feb 2, 2016 at 3:47 PM
HMAC300
  • 48,601 POSTS
Pull coil wire at dist also see if rotor turns with engine shut off if it does check dist gear
Feb 2, 2016 at 4:06 PM
JOE1953
  • 794 POSTS
i havn't found no coil or spark plugs wires on this car the only thing i found is something like a spark plugs boots and spark plugs under a cover on top of the engine and the little coil pack mount to the cover.
Feb 2, 2016 at 4:54 PM
HMAC300
  • 48,601 POSTS
Take ignition module get tested auto parts
Feb 2, 2016 at 5:21 PM
JOE1953
  • 794 POSTS
where is the ignition module located on the engine?
Feb 2, 2016 at 5:27 PM
HMAC300
  • 48,601 POSTS
by the coil pack if this is a 2.4L then under the coil cover. if not then by the coils themselves I can be of no further assistance on this.
Feb 2, 2016 at 5:35 PM
