Engine will crank but will not start up?
STUDMAN
  • 2000 CHEVROLET MALIBU
No scan codes, getting spark, getting fuel, has good comp. Checked all fuses and relays. Ben driveing good parked it the next day will not start ben trying everything for about two weeks now and nothing. It's a malibu LS model.V-6. Real nice car but ready to pull hair out
Wednesday, January 27th, 2021 AT 6:04 PM (Merged)
  • 109,885 POSTS
Hi:
First, don't pull your hair out.
Second, have you actually checked the fuel pump pressure? Will the engine fire with starting fluid?
If you have spark, is it a good hot blue spark?
If you have spark, fuel, and compression, it should run unless it jumped time. When you shut it of the prior night, was everything as normal?
STUDMAN
I didn't put a gauage on the fuel rail to know exzack but from pushing on the valve stem on the rail it seems to have good presure to me.
I tryed to heat-up a copuple plugs in my stove oven and spraying starting fluid in the cyl. And put the plugs back in hot to aid the fireing but nothing.
Yes it is a good spark, I even checked a couple
plugs, not just one.
Yes eveverything was normal when I shut it off the night before. It was driven all that day with no problem.
Just a little footnot, I do and have ben working on cars now for quite a while so I do know quite a bit already. It's just this one got me stumped.
  • 109,885 POSTS
Have you checked to see if the injectors are firing? Even if there is pressure in the rail, the injectors may not be firing.
Is the security light on? if so try the procedure below
https://www.2carpros.com/articles/how-to-reset-a-security-system
  • 109,885 POSTS
Hi:
I'm starting to understand why you are pulling your hair out, and I don't have much left. (LOL) If you have spark, compression, and fuel, the engine should run or at least try to. Like you said, it is possible that the timing is out. Does the engine sound normal when cranking?
STUDMAN
Yes the motor sounds normal when it is turned over, it sounds like it just keep cranking with nothing, like it dosen't even try. The only thing that is different which seen odd to me is that if I releave the the fuel presure at the fuel rail by the ues of the valve stem and try it for the first couple of turns it stumbles a little like it's trying then it just keep cranking with nothing no attemp or anything, at other times I releave presure and nothing will happen at all I know it's still getting spark, and there plunty of gas in the tank.
  • 109,885 POSTS
Hi:
It almost sounds like you may be getting too much gas (bad regulator) based on it trying to start after the pressure is released. See if you can find the fuel pump fuse and pull it. See if it will fire for a second or two. Or, you need to check fuel pump pressure.
Let me know which way you want to try it.
STUDMAN
No fuel pump fuse, pulled relay and tried it. Im falling back on timing chain skipped
