2001 Chevy Malibu car won't start
CEE-CEE1
Other Category problem
2001 Chevy Malibu 6 cyl Wheel Drive Type unknown Automatic 111251 miles
my car won't turn over.the oil can light was coming on when put on my brakes to stop.
Jan 7, 2008 at 1:52 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e44e772bfb="cee-cee1"]Other Category problem
my car won't turn over.the oil can light was coming on when put on my brakes to stop.[/quote:e44e772bfb]
did you run out of oil
have you checked the oil level
does the engine crank but no start
you let me know
Jan 7, 2008 at 11:15 AM
CEE-CEE1
I checked the oil and it is at the add oil line.But i just got oil put in about 3wks ago.should the oil run out that fast!Today went out to start it up, it didn't even try to turn over.The more i tried to turn it over the less juice i got. Thanks for your response.
Jan 8, 2008 at 6:56 AM
BMRFIXIT
  • 19,053 POSTS
[quote:dfcce91a11="cee-cee1"]I checked the oil and it is at the add oil line.But i just got oil put in about 3wks ago.should the oil run out that fast!Today went out to start it up, it didn't even try to turn over.The more i tried to turn it over the less juice i got. Thanks for your response.[/quote:dfcce91a11]
So its not turning
did you try to get a jump ?
try to turn the engine manually
get a wrench and a socket to fit on the crank shaft bolt and try to turn it by hand
if it does then the motor isn’t seized
and you have to check starter and battery
Jan 8, 2008 at 9:01 AM
