Dec 4, 2019 at 4:43 AM
(Merged)
Car stalls while driving
Alright remove the battery cable ends and make sure there clean and not corroded then tighten them up.Had a feeling it was something like that also have the battery and alternator tested.Let me know what you find.
If I drive at a steady rpm for over 40 seconds car shut off and have to reset ECU with a OBD2 scanner so it can start up again, what is causing this.
Does not make a difference what speed does if rpm is study for more seen 40 seconds it shuts off and won't turn back on unless I reset codes with a OBD2 scanner.
(Merged)
What code is popping up that you have to erase to keep it going again
(Merged)
P0101
(Merged)
Try cleaning the MAF sensor with an electronic cleaner and see what happens
(Merged)
Cleaned it and replaced it but still the same. Could it be BCM?
(Merged)
my car turns on for about 10 minutes without problem, but then shuts off and will not start for nothing, 1 hour later the engine running again when I drive the engine feels its shutting off i have to giv it a lot of gas but it shut off again i dont know why if its the pompe the gas, sensor,
(Merged)
Next time it refuses to start don't wait for it to make up its mind-do below immediately to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if okay-check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
(Merged)
🔧 Tools & Auto Repair Parts
Find automotive tools, diagnostic equipment, and replacement
parts for your next repair.
Shop on Amazon →
