Yes. The starting then stalling is a security indicator that there is an issue with the security authentication.
You should have codes in the system if you are able to get them scanned. That will help identify what the issue is. Unfortunately, there is no way to bypass it so you will need to address the issue.
You leaving the key in the ignition in the on position is a way of bypassing it. More than likely the key needs to be left in for a minute or up to 10 minutes before it allows the start. This is basically a way for the truck to prevent it from being stolen. A thief is not going to want to sit around and wait for it to time out.
Let me know what the codes are and we can go from there. Thanks
https://www.2carpros.com/articles/how-to-reset-a-security-system
Wednesday, August 14th, 2019 AT 5:13 PM
