Starter not cranking the engine over?
JIS001
  • 3,411 POSTS
If it is an aftermarket system then you may have tapped into a power wire you should have not to. To start with, if the clicking was fast and dash lights were flickering then you need to have the battery checked out first. Any parts store will most likely do it for you. If it was just one click then I would suspect a faulty starter but you need to verify the battery is healthy enough to support all the loads you have.
Monday, August 31st, 2020 AT 12:47 PM (Merged)
CHRISTAL1
  • 6 POSTS
It is aftermarket. (2 12 inch and a 820 amp.) It has been wired the same way it always has been, I have had it for almost three years. Except moving the ground from the amp. The vehicle only clicks once. I just replaced the starter and battery. The battery reads 13.8 on my capacitor. The vehicle only does this when I connect the power cord from the amp to the terminal. When its not connected it works perfectly fine.
STEVE W.
  • 14,015 POSTS
Sounds like a bad battery or the amp or capacitor is bad. 13.8 cannot be resting battery voltage, The best a battery can generate is around 12.6-12.8 volts. They have six cells that each make 2.1-2.14 volts.
Have the battery and alternator tested to be sure they are okay. If they test good then you can try connecting just the amp alone, then try just the cap alone. Whichever one causes the problem is the issue.
JIS001
  • 3,411 POSTS
Thank you Steve. Was going to same something about the capacitor voltage since that is there to store voltage for the sound system and is not used to start the vehicle up.
As Steve suggested, have the battery tested. You may need to upgrade on your battery to a gel type battery.
CHRISTAL1
  • 6 POSTS
The battery was 12.6 when we tested it.
STEVE W.
  • 14,015 POSTS
How many amps? Voltage is useless without knowing how many amps it can supply. That is why you load test a battery and charging system.
Related Engine Not Cranking Over Content
Car Not Cranking? Try This | EASY
VIDEO
