2014 Ford F-150 P0345 P0349 Sensor Location
150,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
PABLO CHACON
  • 5 POSTS
Good afternoon y’all, trying to find the Camshaft Position sensor A bank 2 location. Would really appreciate your help in locating this so I can fix it. I’m getting a P0345 and P0349 code on my scanner.
Oct 9, 2020 at 3:32 AM
Good afternoon,
I attached the possibilities for you below as well as the procedure for the cam sensor.
Check the voltage to the sensor as well. You need 5 volts with the key on.
The sensor is on the back of the left cylinder head. There are 2. If I were you, I would replace both while you are there.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Camshaft Position (CMP) Sensor - 5.0L (4V)
Removal
Both RH and LH intake Camshaft Position (CMP) sensors and RH exhaust CMP (Camshaft Position) sensor
1. Disconnect the Camshaft Position (CMP) sensor electrical connector.
2. Remove the bolt and the CMP (Camshaft Position) sensor.
LH exhaust Camshaft Position (CMP) sensor
3. Position the vehicle on a hoist. For additional information, refer to vehicle Jacking and Lifting. See: Vehicle Lifting > Procedures > Jacking and Lifting
4. If equipped with 4 wheel drive, index-mark the front flange to the pinion flange.
5. If equipped with 4 wheel drive, remove the 6 front flange-to-pinion flange bolts and 2 washers and position the driveshaft aside.
Discard the 6 bolts and 2 washers
6. Remove the 2 bolts and the LH heat shield from the rear of the LH cylinder head.
7. Disconnect the CMP (Camshaft Position) sensor electrical connector.
8. Remove the 2 transmission support insulator nuts.
9. Remove the CMP (Camshaft Position) bolt.
10. NOTE: Make sure the transmission jack contacts the outer ribs of the transmission fluid pan.
Position a suitable high-lift transmission jack under the transmission. Raise the transmission until the CMP (Camshaft Position) sensor can be removed.
Remove the CMP (Camshaft Position) sensor.
Installation
1. NOTE: The bolt must be torqued while the transmission is raised
Position the Camshaft Position (CMP) sensor and install the bolt.
Tighten to 10 Nm (89 lb-in).
2. Using the suitable high-lift transmission jack, lower the transmission and install the 2 transmission support insulator nuts.
Tighten to 103 Nm (75 lb-ft).
3. Connect the CMP (Camshaft Position) sensor electrical connector.
4. Position the LH heat shield onto the rear of the LH cylinder head and install the 2 bolts.
5. If equipped with 4 wheel drive, position back the driveshaft, align the index mark and install 2 washers and 6 new bolts.
Tighten to 55 Nm (41 lb-ft).
Both RH and LH intake CMP (Camshaft Position) sensors and RH exhaust CMP (Camshaft Position) sensor
6. Position the CMP (Camshaft Position) sensor and install the bolt.
7. Connect the CMP (Camshaft Position) sensor electrical connector.
Oct 9, 2020 at 5:52 AM
PABLO CHACON
  • 5 POSTS
Thanks! So if I’m looking at the engine from the front of the truck that bank two sensor A is which side? That’s a thing I can’t seem to find it looking at the engine if you could have a diagram etc., of the engine and a indication of where it is located that would be great. The dealer replaced the sensor the other day. And then the check engine light came on again so he’s ordered a pigtail wiring etc. The dealership is an hour away from me I’m just trying to see if I could mess with it just to get it to work so my truck doesn’t drive badly.
Oct 9, 2020 at 6:17 AM
Drivers side is the location.
I attached a picture already. The left side is the same. It is on the very back of the head and not easy to access.
I lay across the top of the engine to get back there.
Oct 9, 2020 at 6:24 AM
PABLO CHACON
  • 5 POSTS
So is it in the very back by fire wall? If you could circle the location on my picture. Thanks for your help.
Oct 9, 2020 at 7:01 AM
I attached a picture and circled the sensors in my previous responses.
Oct 9, 2020 at 7:16 AM
PABLO CHACON
  • 5 POSTS
Thanks for your replies. So where I’m pointing out here with the yellow arrow is that it?
Oct 9, 2020 at 7:51 AM
No, the sensors are in the back of the head by the firewall. See the picture I posted and they are on the back of the head.
Oct 9, 2020 at 8:06 AM
PABLO CHACON
  • 5 POSTS
So, this right here “wire” how the heck do I get to it is there easier way? I just want to unplug the sensor clean it off and plug it back in just to see if that works before I go to my car dealership appointment on Monday.
Oct 9, 2020 at 8:29 AM
Yep, that is where they are.
The instructions tell you to get it from underneath as I posted.
I was able to get them from the top by laying on the motor and moving the harness out of the way.
An engineer designed that, go figure.
Oct 9, 2020 at 8:32 AM
Suggested Repair
Locate camshaft position sensor A bank 2 on the driver's side (left) cylinder head at the rear by the firewall. Confirm about 5 volts at the sensor with the key on and inspect the connector and pigtail. Access is from underneath per the service procedure, or from above by moving the harness. The dealer already replaced the sensor and ordered a wiring pigtail; if the codes return, address the wiring rather than only the sensor. Replacing both rear sensors is reasonable while access is open.
Conversation Summary
A 2014 Ford F-150 owner asked where camshaft position sensor A bank 2 is after codes P0345 and P0349. The expert said the sensors are on the back of the left (driver's side) cylinder head by the firewall, not where the owner first pointed, and advised checking for 5 volts with the key on. Access is difficult: the procedure reaches the left exhaust sensor from underneath, though the expert has reached them from above by moving the harness. The dealer had already replaced the sensor and ordered a wiring pigtail after the light returned.
