2018 Ford F-150 Cam Timing Install
8,500 MILES • 5.0L • V8 • 4WD • AUTOMATIC
JORGE LUQUIN
Need a diagram and procedure on how to install the cams and VCT timing chains as well with the main timing chains on the truck listed above. i bought a short block and I'm going to assemble it.
Oct 7, 2021 at 5:10 PM
SQM
  • 6,383 POSTS
I have attached the timing chain, cam and the VCT timing replacement procedures below.
Please let me know if you need any other information.
https://www.2carpros.com/articles/how-camshaft-variable-valve-timing-works
Oct 8, 2021 at 1:14 AM
JORGE LUQUIN
Thank you very much. this helps a lot. by any chance do you have the head installing instructions and torque specs?
Oct 8, 2021 at 3:23 AM
SQM
  • 6,383 POSTS
You are welcome.
I have attached the cylinder head replacement procedure including the torque sequence and specifications.
Let me know how it turns out.
Oct 8, 2021 at 4:00 AM
JORGE LUQUIN
Okay, thank you. one last question so since I'm going to start on a new short block in what position do i place the crankshaft keyway to start doing the timing? is there a procedure for that or do i start at 3:30?
Oct 8, 2021 at 4:20 AM
SQM
  • 6,383 POSTS
You want to keep the keyway at 3:30 after you remove the chain and when you install the chain.
Oct 8, 2021 at 4:30 AM
TRYBIN88
  • 12 POSTS
I have a 2020 Ford f150, with skipped timing. How do I re-install the timing in the correct way, I see you have the steps here but what position does the crankshaft have to be in to begin the process. Would this procedure still apply if my timing is already messed up? What position does the camshafts have to be in the neutral position, also the crankshaft?
Nov 10, 2024 at 12:20 AM
  • 55,688 POSTS
Please refer to your question.
https://www.2carpros.com/questions/engine-is-not-timed
Let us know if you need anything else.
Nov 11, 2024 at 12:44 AM
Suggested Repair
Keep the crankshaft keyway at the 3:30 position when the timing chain is removed and when it is reinstalled. Use the attached camshaft, VCT, main timing-chain, and cylinder-head procedures, including the head torque sequence and specifications.
Conversation Summary
The owner of a 2018 Ford F-150 was assembling a short block and asked for camshaft, VCT, and timing-chain installation guidance, then for cylinder-head instructions and torque specs. The expert supplied the relevant procedures and said the crankshaft keyway should remain at 3:30 during chain removal and installation. A later question about a 2020 F-150 with skipped timing was redirected to a separate thread.
