Replace the serpetine belt on a 97 F-150
RON65NASCAR
  • 1997 FORD F-150
Ford Truck F-150 4wd, 5.4 L, Automatic
156,000 miles.
How do I replace the serpetine belt, where do I losen its tension.
Tuesday, August 7th, 2007 AT 11:23 PM
INDYUKE
  • 416 POSTS
There is a idler pulley near the top, front of the engine. A coil spring supplies the tension for it to hold the belt tight. Put a long wrench on the bolt in the middle of the pulley and pull up and away from the belt. You're not trying to remove the bolt, only pulling the pulley away from the belt.
Wednesday, August 8th, 2007 AT 5:03 PM
