Cadillac STS P0741 Torque Converter Code
DAVIDAMEKKER
On my scanner I'm getting a 0741 code, and when I erase the code it dosen't come back until a week or so of driving
Oct 3, 2007 at 1:20 PM
BUZZSAW
  • 1,198 POSTS
[quote:9381c8c7f4="davidamekker"]On my scanner I'm getting a 0741 code, and when I erase the code it dosen't come back until a week or so of driving[/quote:9381c8c7f4]
input shaft speed sensor, dont let this go on may have some real trouble. other wise the sensor needs replacing and two others and the harness inside the trans, worst case: the shaft to the pump may have bad bearing causing it to wabble this is not good
Oct 5, 2007 at 4:56 AM
Suggested Repair
Do not ignore the recurring P0741. Check and replace the input shaft speed sensor if faulty, and also inspect the other speed sensors and the internal transmission harness. Worst case, a bad pump-shaft bearing may be causing shaft wobble and needs further diagnosis.
Conversation Summary
The owner of a Cadillac STS reports scanner code 0741 that returns after about a week of driving once cleared. The expert warns not to let it continue and points to the input shaft speed sensor, possibly two other sensors and the internal transmission harness, with a worn pump-shaft bearing as a worst-case cause.
