P0404, P0420, P0741, and P1660
How do i trouble shoot these codes and what do I need to do to correct them?
Diagnose each code separately: P0404 as an EGR fault; P0420 as low catalytic efficiency, checking oxygen sensors and a restricted converter; P1660 as a cooling-fan control circuit issue involving the fan, wiring, relay, or PCM ground; and P0741 as a torque-converter clutch stuck off, which commonly requires a transmission overhaul.
The owner of a 1997 Cadillac STS asked how to troubleshoot and correct codes P0404, P0420, P0741, and P1660. The expert identified P0404 as an EGR fault, P0420 as low catalytic-converter efficiency possibly caused by oxygen sensors or a backed-up converter, P1660 as a cooling-fan control circuit problem involving the fan, wiring, relay, or PCM ground, and P0741 as a torque-converter clutch stuck off that commonly requires transmission overhaul.
