1997 Cadillac STS Coolant Loss
BUSTERBROWN
while looking at your page. I noticed that you told someone to run a cyl.leak down test to determin if they had a head gasket or head problem. How does one run such a test? I have a 97 4.6 sts cadi. that over heats . cant keep coolent in it. motor runs great no misses. and do you know where or what web site I can go to to find info. w/ pictures showing how to tear down engine to make repairs. I have a chilton manual for this year model, but its not very clear as to location of parts to be removed . I have made a donation, hope it will help you guys..
Apr 12, 2007 at 12:54 PM
2CARPRO JACK
  • 11,533 POSTS
What you need is a "chemical" test of the cooling system. It detects exhaust in the coolant. Northstar? You will probably have to go to the repair manuals link at the bottom of the main forum page and sign up to Mitchell-On-Demand, same software the pro's use. More info than a manual you can buy
Apr 13, 2007 at 1:15 AM
Suggested Repair
Perform a chemical cooling-system test that detects exhaust gases in the coolant to check for a head gasket or cylinder-head problem. For clearer teardown and repair procedures than a Chilton manual, use Mitchell-On-Demand service information.
Conversation Summary
The owner of a 1997 Cadillac STS 4.6 that overheats and loses coolant, but runs smoothly with no misfires, asked how to perform a cylinder leak-down test and where to find illustrated engine teardown information. The expert recommended a chemical cooling-system test to detect exhaust in the coolant and suggested Mitchell-On-Demand manuals for more detailed repair procedures.
