HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Cadillac
Fleetwood
Engine
Symptoms
Not Running
1984 Cadillac Fleetwood I plugged my baterie has upside
MECANICBOY
MEMBER
1984 CADILLAC FLEETWOOD
V8
2WD
AUTOMATIC
120,000 MILES
Since I plugged my baterie al upside down, (+ in - and - on the +) since my car don't starts.
Wednesday, August 27th, 2008 AT 12:01 AM
MECHANIC
Hi there,
Start with checking all engine & ecu fuses and and fusible links, also have the ECU checked as you may have spiked and it has been damaged.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, August 27th, 2008 AT 12:43 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1990 Cadillac Fleetwood Car Will Not Start
The Car Will Not Start. I Pulled The Starter And Had It Checked Out (with The Solenoid Attached To The Side). Both The Starter And Solenoid...
Asked by
2CP-Archives
1990
CADILLAC FLEETWOOD
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1992 Cadillac Fleetwood Will Not Start
This Car Has All Ways Started. I Put A New Battery In It An It Will Not Start, It Will Turn Over. If I Put Gas In The Carb It Will Start Up...
Asked by
fbdrake
1 ANSWER
1992
CADILLAC FLEETWOOD
1989 Cadillac Fleetwood Will Not Start
I Have Put A New Starter On And Cillanoad. Battery New. Its Like If I Open The Hood And Its Gold Out 10 Min It Starts. Alll Works.A Hot Day...
Asked by
marktx
1989
CADILLAC FLEETWOOD
Engine Wouldn't Start
I Have A 93 Cadillac Fleetwood 5.7l Drove The Car To Six Stores The Last One Wouldn't Start How Do You Tell If It Is The Fuel Pump? Turns...
Asked by
vince lettau
1993
CADILLAC FLEETWOOD
1991 Cadillac Fleetwood Wont Start
1991 Cadillac Fleetwood V8 Two Wheel Drive 125000 Miles My Car Won't Start. The Belts And Pully's Turn And The Electrical Is On In The...
Asked by
hpeckham
1 ANSWER
1991
CADILLAC FLEETWOOD
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
