1988 Cadillac Deville Blower Won't Shut Off
SLLY1791
1988 cadillac deville 4.5 liter 218,000 miles. i recently put a new blower motor in car now it wont shut off unless i unhook it or disconnect the battery cable. is there a relay or something else i need to do after replacing blower motor or do you think it has something to do with the climate control power module?
Feb 18, 2007 at 4:03 PM
CHEVY22
  • 1,375 POSTS
i would check the relay it is located in the d position of the relay center, the relay may be stuck on , or it could be a problem with the climate control module , i would check the relay first and go from there
thanks
Feb 19, 2007 at 2:20 AM
Suggested Repair
Check the blower relay in the D position of the relay center first, since it may be stuck on. If the relay checks out, inspect the climate control power module.
Conversation Summary
The owner of a 1988 Cadillac Deville replaced the blower motor, and the blower now runs continuously unless it is unhooked or the battery is disconnected. The expert recommends checking the relay in the D position of the relay center first, then considering a problem with the climate control module.
