1997 Cadillac Deville Blower Motor No Heat
ANTWON
hi' i got a 97 deville and the blower motor [heat] wont go on, there are 3 wiresgoing to it red,grey blk the red is gettin 12volts blk is grounded but the grey is supposed to be fan speed control. no power is going to it i would assume it should send signal to turn on? then i powered the blower with my own jumpers after unhooking the plug 12v to red terminal on motor gnd to blk and power to grey and nothing a new 1 is like 250 and seems weird that there are 2 problems am i missing somthing? then i got a code po340 on my scanner so i checked connections looked ok i changed sensor and still comes back but if i clear codes and hold rpm above 1600 it will not set until idle any help would be app. thanks
Oct 17, 2007 at 11:19 AM
BUZZSAW
  • 1,198 POSTS
[quote:a979fc8d33="antwon"]hi' i got a 97 deville and the blower motor [heat] wont go on, there are 3 wiresgoing to it red,grey blk the red is gettin 12volts blk is grounded but the grey is supposed to be fan speed control. no power is going to it i would assume it should send signal to turn on? then i powered the blower with my own jumpers after unhooking the plug 12v to red terminal on motor gnd to blk and power to grey and nothing a new 1 is like 250 and seems weird that there are 2 problems am i missing somthing? then i got a code po340 on my scanner so i checked connections looked ok i changed sensor and still comes back but if i clear codes and hold rpm above 1600 it will not set until idle any help would be app. thanks[/quote:a979fc8d33]
blower motor bad
Oct 29, 2007 at 3:39 AM
Suggested Repair
Replace the blower motor. The expert did not address the returning P0340 camshaft sensor code.
Conversation Summary
The owner of a 1997 Cadillac Deville reports that the heater blower will not run. The red wire has 12 volts, the black wire is grounded, and the gray speed-control wire has no signal. Applying power directly to the unplugged motor did not make it run. A P0340 camshaft sensor code returns at idle after the sensor was replaced, but does not set when engine speed is held above 1600 rpm. The expert states that the blower motor is bad.
