1990 Cadillac Deville No Blower
KEITHFOSTER
I have a 1990 Cadillac SedanDeville. Neither the A/C nor the Heater is blowing out. I've checked the relays and fuses and they are okay. I've replaced the blower motor and it still isn't blowing out. The engine is 4.5 liter(V8). 86,000 miles. Please help.
Feb 23, 2007 at 1:04 AM
MATHIASO
  • 1,209 POSTS
How did you check the relay and fuse?
Feb 23, 2007 at 12:28 PM
KEITHFOSTER
[quote:c05f8262a1="mathiaso"]How did you check the relay and fuse?[/quote:c05f8262a1]
I inserted other working relays to see if the relay is the problem. I visually checked the fuse to see if it was bad. Also, the ac/htr comes on sometimes however, it doesn't work more times than it does .When it does come on, it doesn't blow out strongly.
Feb 28, 2007 at 1:55 AM
MATHIASO
  • 1,209 POSTS
check for stuck door in the ductwork
Feb 28, 2007 at 3:07 AM
Suggested Repair
Check the HVAC ductwork for a stuck blend or mode door that could block airflow from both the heater and A/C.
Conversation Summary
The owner of a 1990 Cadillac Sedan Deville with a 4.5L V8 reports that neither the heater nor the A/C blows air. Relays were swapped with known-good units, the fuse was visually inspected, and the blower motor was replaced, but airflow is still absent most of the time and weak when it does come on. The expert advised checking for a stuck door in the ductwork.
