2005 Cadillac Deville air not blowing
85,000 MILES • V8 • 2WD • AUTOMATIC
05CADDYGIRL
can you tell me if there is a relay switch for the ac. it lights up likes it wants to come on but nothing blows out
Sep 5, 2010 at 9:24 AM
FACTORYJACK
  • 4,159 POSTS
There is no relay, there is a control module(panel), a speed control processor, and the blower motor. You can check for power at the blower motor connector with a test light across the two terminals. If it lights, you need a blower motor. If it does not light, most likely the speed control processor is at fault. You can try rapping on the blower and see if you get operation out of it. If it comes back to working, there is no telling how long it will work.
Sep 8, 2010 at 3:49 PM
