1997 Cadillac Deville A/C Not Cooling
ROG
  • 5 POSTS
HI I HAVE A 97 DEVILLE 162000 MILES NORSTAR THE A/C CLUCH STAYS ON ALL THE TIME AND THE A/C LINE RUNING ACROSS THE FIREWALL GETS VERY HOT THERE IS R134A IN IT BUT THE A/C WONT WORK PLEASESSSSSSS HELP
Jun 3, 2007 at 6:11 PM
BOOTDOG
  • 665 POSTS
take the vehicle in and have the shop hook up an a/c machine to check pressure, it's possible there is a blockage in the system not allowing the freon to circulate properly.
Jun 3, 2007 at 11:01 PM
ROG
  • 5 POSTS
would that explain the line having frost on it but no cold air coming out the vent then it got very very hot like a hot exhaust pipe
Jun 4, 2007 at 1:26 AM
BOOTDOG
  • 665 POSTS
yes it would. get the pressure checked, then go from there. let us know how we can help afterwards.
Jun 4, 2007 at 1:19 PM
ROG
  • 5 POSTS
i found out the problem with the a/c line geting hot the orfice filter was cloged and the high side a/c line sensers were bad and with the a/c compresser runing all the time someone jump the a/c compresser relay so i replaced the relay, repaced sensers,orfice fiter,and put 2 cans of r134a and 1 can of oil and got ice cold air so mybe this post can help someone
Jun 6, 2007 at 4:07 PM
BOOTDOG
  • 665 POSTS
i'm glad it worked out.
Jun 6, 2007 at 9:04 PM
Suggested Repair
Have A/C system pressures checked for a blockage. On this car, a clogged orifice filter, bad high-side line sensors, and a jumped compressor relay were replaced; refrigerant and oil were added, and cooling returned.
Conversation Summary
A 1997 Cadillac Deville with a Northstar had an A/C clutch that stayed engaged, a firewall line that became very hot, and no cold air despite R134a in the system. The expert recommended a shop pressure test for a possible blockage. The owner later reported a clogged orifice filter, bad high-side sensors, and a compressor relay that had been jumped. Replacing the relay, sensors, and orifice filter, then adding two cans of R134a and one can of oil, restored ice-cold air.
