2000 Cadillac Deville white exhaust smoke
145,000 MILES • V8 • FWD • AUTOMATIC
JARMINIAK
Mt car just started blowing white exhaust smoke when i start it. It goes away after a couple of minutes. It has thet sweet maple smell so i think it is coolant.
The check engine light has been on for the last 30,000 mile but it is only in the last 3 weeks I have noticed the smoke. I have always checked the coolant every two weeks. It is only in the last few weeks that I have noticed it down about a gallon.
The oil looks good.
The passanger side vents blew cold air last winter if that has anyting to do with it.
May 11, 2008 at 12:04 PM
BLACKOP555
  • 10,386 POSTS
i would say bad head gasket or intake manifold gasket.
i wouldnt be so sure about the headgasket because it would keep going even when warm.
with the intake gasket it will keep leaking coolant into the cylinders when vehicle is off and when it is started it will keep burning it untill no more is present then the smoke stops.
May 11, 2008 at 1:37 PM
BUZZSAW
  • 1,198 POSTS
[quote:d59fc71e9c="blackop555"]i would say bad head gasket or intake manifold gasket.
with the intake gasket it will keep leaking coolant into the cylinders when vehicle is off and when it is started it will keep burning it untill no more is present then the smoke stops.[/quote:d59fc71e9c]
white smoke could also be oil smoke, have you cooling sys pressure tested for leaks, if its not overheating its not your headgaskets, no coolant runs through the intake, and do a oil level test, fill it and recheck it in a week if its low its oil
May 12, 2008 at 2:06 AM
BLACKOP555
  • 10,386 POSTS
sometimes they dont over heat though, but as i was saying it wouldnt stop going right away,
check with cooling system as buzzsaw states.
May 12, 2008 at 9:02 AM
BUZZSAW
  • 1,198 POSTS
[quote:bbbfa503e7="blackop555"]sometimes they dont over heat though, but as i was saying it wouldnt stop going right away,
check with cooling system as buzzsaw states.[/quote:bbbfa503e7]
Black they always overheat first with full coolant
May 13, 2008 at 4:01 AM
JARMINIAK
The garage just told me the #3 cylinger has had 4800 missfires and the plug is whit all the rest are tan. The car now over haets after 10 miles. How do i find out if this is a intake or a head gasket?
[quote:f7ece70d5e="Buzzsaw"][quote:f7ece70d5e="blackop555"]i would say bad head gasket or intake manifold gasket.
with the intake gasket it will keep leaking coolant into the cylinders when vehicle is off and when it is started it will keep burning it untill no more is present then the smoke stops.[/quote:f7ece70d5e]
white smoke could also be oil smoke, have you cooling sys pressure tested for leaks, if its not overheating its not your headgaskets, no coolant runs through the intake, and do a oil level test, fill it and recheck it in a week if its low its oil[/quote:f7ece70d5e]
Jun 3, 2008 at 7:25 AM
BLACKOP555
  • 10,386 POSTS
best way to check is if it is a headgasket failure the compression would show up on that cylinder lower than the average of the rest.
Jun 4, 2008 at 12:48 PM
