1990 Cadillac Deville ***MY Cadillac WONT START, HEEEELP ME
MARKTAYLOR_254
  • 1990 CADILLAC DEVILLE
  • V8
  • FWD
  • 160,000 MILES
I have been experiencing this problem for the pass 3 months and basically Im having trouble getting my car to turn over properly. It started when the wheather changed (from cold to hot), but I replaced the battery and also had the "ignition switch replaced" and a new key made but im still experiencing the same symptoms. My dad told me it could be a bad cell in the battery but im getting the proper readings on my volt meter. I would basically drive the car fine all day and then the next day I go to turn it on, it wouldnt start as if the battery is dead, still displaying all lights and fuel pump active. If I come back out later on that day it might start or itll continue to act dead- doesnt change due to wheater. Starter and Altnator are good to my knowledge, maybe I need to reevaluate them. Could it be a misfire in the spark plugs, because I havent replaced them? LOOKING FOR AS MANY POSSIBILITIES AS POSSIBLY, VERY DESPERATE FOR INFORMATION- PLEASE HELP. THANKS TO ANYONE READING THIS.
Thursday, June 18th, 2009 AT 1:54 PM
FACTORYJACK
  • 4,159 POSTS
If it is a concern with the speed that it turns over when the key is first placed in the crank position, it would not be solved by plugs. Have you got a trickle or otherwise low amps charger that can be placed on it overnight, see how it performs the morning after. A battery can gain some charge as it warms, that could explain it starting after waiting a bit. Have the battery load tested, it should maintain 9-10 volts after 15 seconds of a load that is half the CCA rating. For example if it is a 660 CCA battery, it should remain over 9-10 volts when loaded to 330 amps for 15 seconds. Tight and clean cable connections, tight and clean starter connections, a good-clean engine ground, all can play a part.
Thursday, June 18th, 2009 AT 10:23 PM
MARKTAYLOR_254
  • 21 POSTS
I have a question in regaurds to the Neutral Safety Switch as well. I was following the purple wire from the starter (because it appeared to look a bit rough) to find it connected to the NSS. I just want to know, what is its purpose in relation to the starter/ and how can fixing it help my ignition problem?
Friday, June 19th, 2009 AT 1:59 AM
FACTORYJACK
  • 4,159 POSTS
I don't quite understand your question. The neutral safety switch is just that, it prevents the starter recieving a signal in any gear other than neutral, or park, which is basically neutral with a mechanical lock. What do you mean by 'looking a bit rough', is the insulation cracking and brittle. Could be caused by heat from the exhaust. Bare wire is obviously a potential problem. If you are having a problem with cranking speed, the signal wire is not going to cause it. Just the fact that it is cranking eliminates the signal wire as being the cause.
Saturday, June 20th, 2009 AT 1:20 AM
MARKTAYLOR_254
  • 21 POSTS
Thanks GStacey, I appreciate your help. Very helpful- Well replacing the Neutral Safety Switch didnt resolve my problem but I finally got somewhere working on it today. My dad was using my battery to start his Suburban and he let it run for roughly 30-45 minutes, he took it out and placed it in my car not thinking anything of it but when he started the engine, IT CRANKED! And this car has not been working for a couple of days since we've been examinating it. Im coming to the conclusion that its the Altenator, just for the fact that his Suburban had to have given my battery a charge to manage the crank BUT my alternator check good on the volt meter. Is there a possibility that it could still check good on the meter but be a weak alternator, bad cell in the battery, dont know. Thanks to anyone listening---
Also what is the Amp on a standard Alternator for my vehicle?
Monday, June 22nd, 2009 AT 12:30 AM
