1990 Cadillac Deville #1 cylinder does not fire.
JOE LORENTI
  • 1990 CADILLAC DEVILLE
Engine Mechanical problem
1990 Cadillac Deville V8 Front Wheel Drive Automatic 142k miles
My v8 4.5 cadillac engine is running on seven cylinders. Number 1 cylinder does not fire, I have checked the spark plugs, they are good, wires good, distributor cap is good, cylinder compression is 180psi, which is good. Can you tell me what else it may be?
Wednesday, August 20th, 2008 AT 5:33 PM
JOE LORENTI
  • 6 POSTS
If you are sure your compression is accurate and you truly have 180psi and your spark plug, both plug and wire are good, and have a bright blue spark, than it can only be one of teo possiblities which are: Falty injector and/or a brake in the injector wire, or your rocker arm had detached itself from the push rods, leaving the valves inoperable. Good luck!
Thursday, August 21st, 2008 AT 10:09 PM
