1990 Cadillac Deville engine backfires when trying to start
GO48JJGO
Engine Mechanical problem
1990 Cadillac Deville V8 Front Wheel Drive Automatic 65xxx miles
hey i seem to have a problem when i go to start my car it cranks but it will just backfire out of the exhaust. i have new plugs,wires,cap,coil and fuel filter. wondering what else i can check to resolve this problem. thanks in advance
Nov 21, 2009 at 5:34 AM
  • 75,988 POSTS
Do below:
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Nov 21, 2009 at 6:47 AM
