A/C bracket snapped off, removed A/C, need a belt number for this application.
May 5, 2022 at 5:55 AM
The 1.4 Cruze was not offered without A/C, so no factory bypass belt is available. Measure the belt path around the remaining pulleys with the tensioner retracted and locked, add a few millimeters for installation, and buy a matching belt. A 47.5-inch belt was confirmed to fit and run without a problem.
The owner removed the A/C after its bracket snapped and needed a serpentine belt that bypasses the compressor on a 2014 Chevrolet Cruze. The expert explained that the 1.4 engine was never supplied without A/C, unlike the 1.8, so no off-the-shelf bypass belt exists. They advised measuring the pulley path with the tensioner locked and adding a little length. The owner later reported that a 47.5-inch belt fit and worked.
