1983 Buick Riviera Oil Leak
COSMOKREMER
  • 5 POSTS
Yes.... I know it is an old car
My dad and I are having fun with "find the new oil leak"
We recently acquired this car and it is my "fixer-upper"
The only documented problem was a small oil leak from the valve cover gasket. It took a week to fix.....
We have concluded that the gasket is now fine, but have found a new leak. We think it is coming from the gasket that mates the exhaust manifold with the engine block (o Joy!). However, we cannot see this leak, we can only surmise the little spot of oil is dripping from here. (It is pooling on the right side of the engine about 8 in. below the rear-most spark plug on the exhaust manifold).
I that happens to be the true location of the leak, is it possible if a small fire (from previous leak) that lasted about a minute could have partially melted the gasket enough to allow a leak?
Nov 28, 2007 at 7:33 AM
MERLIN2021
  • 17,250 POSTS
Is the exhaust loud at that spot? If not it's not comming from there, go to a car wash and gegrease the engine, then run the engine until you find the new oil trail..
Nov 28, 2007 at 7:38 AM
Suggested Repair
If the exhaust is not loud at the suspected spot, the leak is not from the exhaust manifold gasket. Degrease the engine, then run it and follow the fresh oil trail to the actual source.
Conversation Summary
The owner of a 1983 Buick Riviera fixed a valve cover gasket leak and then found a new oil drip pooling below the rear spark plug near the exhaust manifold. They wondered whether a brief fire could have damaged that gasket. The expert said a quiet exhaust at that spot means the leak is not there, and advised degreasing the engine and running it to trace the new oil trail.
