1996 Buick Riviera Brake Fluid Leak
First check that the cap is tight on the reservoir and there is plenty of fluid. wash down brake fluid with water, and dry off flexible hose. have someone apply brake pressure and watch hose for leak, they normally leak where they join into the steel fitting that the brake (steel) pipe attaches to, if so you should have all flexible hoses replaced as a precaution. If no leak from hose, check all brake lines for fluid and have that line replaced. IF there is only fluid on the inside of the wheel, check the brake calliper (where the pads are fitted) for fluid, as the piston seals may be leaking.
Mark (mhpautos)
Suggested Repair
Confirm the reservoir cap is tight and the fluid level is full. Wash off the brake fluid, dry the flexible hose, and have someone apply the brakes while watching for leaks at the hose-to-steel fitting. Replace all flexible hoses if one is leaking. If the hose is dry, inspect the steel lines and replace the leaking line. If fluid is only inside the wheel, check the caliper piston seals.
Conversation Summary
The owner of a 1996 Buick Riviera with a supercharged 3800 found brake fluid behind the driver-side front tire and suspected a brake line leak. The expert advised checking the reservoir cap and fluid level, washing and drying the area, then applying the brakes while inspecting the flexible hose, especially where it meets the steel fitting. If the hose leaks, all flexible hoses should be replaced; otherwise the steel lines should be checked and the leaking line replaced. Fluid only inside the wheel may indicate leaking caliper piston seals.
