1983 Buick Riviera Oil Leak
COSMOKREMER
  • 5 POSTS
Yes.... I know it is an old car
120000 mi, 8 cyl olds 307
My dad and I are having fun with "find the new oil leak"
We recently acquired this car and it is my "fixer-upper"
The only documented problem was a small oil leak from the valve cover gasket. It took a week to fix.....
We have concluded that the gasket is now fine, but have found a new leak. We think it is coming from the gasket that mates the exhaust manifold with the engine block (o Joy!). However, we cannot see this leak, we can only surmise the little spot of oil is dripping from here. (It is pooling on the right side of the engine about 8 in. below the rear-most spark plug on the exhaust manifold).
I that happens to be the true location of the leak, is it possible if a small fire (from previous leak) that lasted about a minute could have partially melted the gasket enough to allow a leak?
Nov 28, 2007 at 7:41 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7c17100f99="cosmokremer"]Yes.... I know it is an old car
I that happens to be the true location of the leak, is it possible if a small fire (from previous leak) that lasted about a minute could have partially melted the gasket enough to allow a leak?[/quote:7c17100f99]
Never an easy job to locate and fix an oil leak on old car, my suggestion to you is start by cleaning the engine to the best you can (steam clean if possible) and also where you described the leak, its an exhaust manifold gasket no oil in the area to leak it has to be coming from the top so double check the work u did and also make sure the surface are clean on both engine and cover
Good luck
Nov 28, 2007 at 9:31 AM
Suggested Repair
Clean the engine thoroughly, steam cleaning if possible, then recheck the valve cover gasket repair and mating surfaces. The exhaust manifold gasket does not carry oil, so the drip is likely coming from above.
Conversation Summary
The owner of a 1983 Buick Riviera with an Oldsmobile 307 found a new oil leak after repairing a valve cover gasket. Oil pools on the right side about 8 inches below the rear spark plug near the exhaust manifold, and they asked whether a brief fire could have melted that gasket. The expert said an exhaust manifold gasket has no oil to leak, so the source must be higher up, and recommended cleaning the engine and rechecking the valve cover work and surfaces.
