1988 Buick Riviera Idle Stalling
JUALI
My 1988 buick riviera 3.8L 3800 engine keeps Idleing on acceleration and stalling from time to time. I change the fuel filter, air filter, distributor coil, spark plugs and wires, I also changed mass air sensor but nothing, engine only runs a little smoother but I still get stallling and Idling even sometimes when car is in park. I checked the fule pressure and gas shoots up out the valve. I also can hear fuel pump working when key is turned. And also my seatbelt warning stoped working at the same time. I aslo used fuel injector cleaner and still no change. And there is no check engine light either. can someone please help me out I will gladly appreciate it.
Oct 1, 2007 at 4:21 PM
  • 75,988 POSTS
I checked the fule pressure and gas shoots up out the valve. Wrong! that's the wrong way on checking fuel pressure-you need a fuel pressure gauge to check. The EFI is very picky on fuel pressure. Not right it might refuse to start
Comeback with the actual fuel pressure in the system before we can continue-I need to know this. So that I can re-evaluate your problem is to whether its a fuel or ignition problem.
Oct 1, 2007 at 6:17 PM
  • 75,988 POSTS
Inbox :: Message
To: rasmataz
Posted: Thu Oct 04, 2007 7:41 am
Subject: stumbling on acceleration
When I changed Maf sensor the engine stoped idleing in park or in any position when not accelerating. but when I rev the engine or try to take off it starts stubling on acceleration. there is no check engine light and I just changed the control module and coil so what should I do next?
Next step check the IACV and TPS and also check the EGR
Oct 4, 2007 at 3:49 AM
Suggested Repair
Measure fuel pressure with a proper gauge rather than opening the test valve. Then inspect the idle air control valve, throttle position sensor, and EGR system.
Conversation Summary
A 1988 Buick Riviera with a 3.8L engine stalls at idle and stumbles on acceleration despite replacement of the fuel filter, air filter, coil, plugs, wires, MAF sensor, control module, and use of injector cleaner. There is no check engine light, and the seatbelt warning failed at the same time. The owner heard the fuel pump but checked pressure incorrectly by opening the valve. The expert said a gauge reading is required because the EFI system is sensitive to fuel pressure, then recommended checking the IAC valve, TPS, and EGR.
